Einleitung
Replacing the battery can help with problems related to the laptop not lasting long when not plugged into the wall. You can also consider getting an extended battery to replace the original, if you need more time away from the charger.
Was du brauchst
2 weitere Nutzer:innen haben diese Anleitung absolviert.
