Zum Hauptinhalt wechseln
HP Envy TouchSmart 4-1215dx Headphone Jack Replacement
Was du brauchst
  1. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 2 HP Envy TouchSmart 4-1215dx Headphone Jack Replacement, Back Panel Assembly: Schritt 1, Bild 2 von 2
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement: Schritt 2, Bild 1 von 2 HP Envy TouchSmart 4-1215dx Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement, Fan: Schritt 3, Bild 1 von 1
    • Unplug the fan from the motherboard.
  4. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement: Schritt 4, Bild 1 von 2 HP Envy TouchSmart 4-1215dx Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Remove the four Phillips #0 screws holding in the fan.
    • Pull out the fan.
  5. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement, Headphone Jack: Schritt 5, Bild 1 von 1
    • Unplug bus from motherboard
  6. HP Envy TouchSmart 4-1215dx Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    • Remove the two Phillips #0 screws that hold the headphone jack to the laptop.
    • Pull out to remove.
Abschluss
Gabriel Castro
175 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 169
