Einleitung
Use this guide to help replace your Hard Drive for greater data storage. The Hard Drive is a memory hardware device with the sole purpose of storing and retrieving data.
Was du brauchst
Turn the laptop over so that the bottom is facing up
Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
Using the JIS screwdriver along with the J000 head, unscrew the four Phillips PM2.5x5.5 screws, and place them aside.
Carefully detach the Hard Drive Adapter, and remove the Hard Drive from the laptop.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
