Was du brauchst
Turn the laptop over so that the bottom is facing up
Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
Use the J0 screwdriver to remove the two M2.0x3.0 screws holding in the cooling fan
Use the J1 screwdriver to remove the three M2.5x2.5 screws on the SD card reader.
Remove the SD card reader and set it aside.
Disconnect the six ZIF connectors.
Use the tweezers to flip up the plastic retaining flap.
Pull the cable out horizontally.
Disconnect the four remaining connectors.
Use a plastic opening tool or spudger if necessary to pry the connector apart.
Use the J0 screwdriver to remove the two M2.5x2.5 screws on the wireless network card.
Slide the card horizontally toward the front of the laptop and out of its socket.
Use the J1 screwdriver to remove the four M2.5x2.5 screws that secure the motherboard to the case.
Pull up on the right side of the motherboard, away from the USB ports, then slide out to the right.
