Einleitung
This is a repair guide on how to get to and replace the mouse touch pad.
Was du brauchst
Turn the laptop over so that the bottom is facing up
Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
The mouse touch pad is located in the bottom middle section of the back of the laptop.
Lift the black ZIF tab and gently pull the ribbon cable free.
There are four M2.5X2.5 screws that need to be removed in order to take the mouse touch pad out.
Unscrew all four M2.5X2.5 screws with a JIS #0 screwdriver.
Flip the laptop over and open it.
Gently press on the two top corners of the mouse touch pad, snapping it down and out.
Remove through the bottom of the laptop and replace.
