Zum Hauptinhalt wechseln
HP Envy Touchsmart m6-k125dx Touch Screen Replacement
Was du brauchst
  1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 1
    • Open the laptop.
    • Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
  2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 2, Bild 1 von 2 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 2, Bild 2 von 2
    • Insert pick between the black plastic screen panel and the silver plastic exterior case on the side of the device.
    • Slide pick around the border of the screen panel while keeping the pick between the mentioned panel and exterior case.
    • Repeat previous two steps until exterior case is removed. Pry with minimal force if necessary.
  3. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 3, Bild 1 von 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 3, Bild 2 von 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the front panel from the rest of the device and set it aside.
    • Remove the ten M2.5x2.5 screws with the J0 screwdriver.
    • Remove the eight M2.0x2.0 screws with the J0 screwdriver.
  4. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 4, Bild 1 von 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 4, Bild 2 von 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 4, Bild 3 von 3
    • Flip hinges down and away from the rest of the panel.
    • Remove the four M2.5x2.5 screws with the J0 screwdriver.
    • Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
    • Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
  5. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: Schritt 5, Bild 1 von 1
    • Slowly lift the screen away from the touch screen front panel to remove.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S14-G14, Wilson Spring 2019 Mitglied von IUPUI, Team S14-G14, Wilson Spring 2019
IUPUI-WILSON-S19S14G14
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 870
