Zum Hauptinhalt wechseln
HP Envy Ultrabook 4-1015dx Battery Replacement
Was du brauchst
  1. HP Envy Ultrabook 4-1015dx Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 3, Bild 1 von 2 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 3, Bild 2 von 2
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 4, Bild 1 von 2 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 5, Bild 1 von 2 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 5, Bild 2 von 2
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 6, Bild 1 von 2 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 6, Bild 2 von 2
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 7, Bild 1 von 2 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 7, Bild 2 von 2
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 8, Bild 1 von 3 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 8, Bild 2 von 3 HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 8, Bild 3 von 3
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Battery Replacement: Schritt 9, Bild 1 von 1
    • Lift up the battery and remove it from the device.
Abschluss
UMass Dartmouth, Team S1-G3, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G3, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 561
