Zum Hauptinhalt wechseln
HP Envy Ultrabook 4-1043cl Cooling Fan Replacement
Was du brauchst
  1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 2, Bild 1 von 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 4, Bild 1 von 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 5, Bild 1 von 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 2 von 2
    • Remove one 4.2mm screw at the bottom right corner by using the Phillips #00 screwdriver.
  7. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 7, Bild 1 von 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the fan from the motherboard and remove it from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 220
