Zum Hauptinhalt wechseln
HP Envy X2-15-C001Dx Back Panel Replacement
Was du brauchst
  1. HP Envy X2-15-C001Dx Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 2, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 3, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 3, Bild 2 von 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 5, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 5, Bild 2 von 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 7, Bild 1 von 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 8, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 8, Bild 2 von 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 9, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 9, Bild 2 von 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 10, Bild 1 von 2 HP Envy X2-15-C001Dx Back Panel Replacement: Schritt 10, Bild 2 von 2
    • Remove the back panel from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 214
