Zum Hauptinhalt wechseln
HP Envy dv6-7363cl Fan Replacement
Was du brauchst
  1. HP Envy dv6-7363cl Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: Schritt 2, Bild 1 von 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: Schritt 3, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: Schritt 4, Bild 1 von 1
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 6, Bild 3 von 3
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 7, Bild 3 von 3
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 8, Bild 3 von 3
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: Schritt 9, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 9, Bild 2 von 2
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 10, Bild 3 von 3
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 11, Bild 3 von 3
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: Schritt 12, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 12, Bild 2 von 2
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 1 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 2 von 3 HP Envy dv6-7363cl Fan Replacement: Schritt 13, Bild 3 von 3
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: Schritt 14, Bild 1 von 2 HP Envy dv6-7363cl Fan Replacement: Schritt 14, Bild 2 von 2
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: Schritt 15, Bild 1 von 1
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
dylananthony
564 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Antwort
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 4,620
