Einleitung
Reader will be able to successfully replace their keyboard of the device. A basic understanding of simple tools such as a screwdriver is needed. Any form of electricity must be removed from device, including the charging cable and battery.
Was du brauchst
Pry off the keyboard retainer slowly working your way around the board to prevent damage
Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board
Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard.
Ein Kommentar
Salom shu kampyuterni ustgi qopqogʻi kerak topishni iloji bormi
