Zum Hauptinhalt wechseln
HP Envy dv6-7363cl Wi-fi Card Replacement
Was du brauchst
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 2, Bild 1 von 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 3, Bild 1 von 2 HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 1
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 6, Bild 1 von 1
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 7, Bild 1 von 2 HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 8, Bild 1 von 2 HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 8, Bild 2 von 2
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 9, Bild 1 von 2 HP Envy dv6-7363cl Wi-fi Card Replacement: Schritt 9, Bild 2 von 2
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
dylananthony
564 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 415
