Einleitung
Use this guide to replace a faulty hard drive on your HP Envy dv7t-7200 if your laptop is running slowly, begins freezing, or has corrupt files. There are two hard drives within this laptop that can be removed and replaced in a few steps.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Place the computer on its top on a flat surface with the hinges facing away from you.
Slide the battery release latch to the left which is located on the right-hand side of the battery.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Slide the service cover toward the front of the laptop.
Lift the service cover to remove it from the laptop.
Remove the 2 Phillips PM2.5×5.5 top screws from brackets on both hard drives.
To reassemble your device, follow these instructions in the reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
