Zum Hauptinhalt wechseln
HP Envy dv7t-7200 Service Cover Replacement
Was du brauchst
  1. HP Envy dv7t-7200 Service Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Service Cover Replacement: Schritt 2, Bild 1 von 3 HP Envy dv7t-7200 Service Cover Replacement: Schritt 2, Bild 2 von 3 HP Envy dv7t-7200 Service Cover Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Service Cover Replacement: Schritt 3, Bild 1 von 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Service Cover Replacement, Service Cover: Schritt 4, Bild 1 von 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Service Cover Replacement: Schritt 5, Bild 1 von 2 HP Envy dv7t-7200 Service Cover Replacement: Schritt 5, Bild 2 von 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Krystal
882 Reputation
8 Anleitungen geschrieben
UW Tacoma, Team S3-G3, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Mitglieder
Ein Kommentar
I broke my computer. And I think it needs a new housing but I don’t know how much it costs
Elisha meyer Luwagga - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 382
