Einleitung
This is a simple procedure to remove and replace your battery. You won't need any tools for this step. Simply slide the battery release lever and lift out the battery.
Turn the computer completely off.
Disconnect any devices you have on it.
Turn the computer upside down on a flat surface.
Push the battery release latch with one hand.
Grab the battery with the other hand.
Lift out on an angle.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
