Zum Hauptinhalt wechseln
HP Envy m6-1105dx RAM Replacement
  1. HP Envy m6-1105dx RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx RAM Replacement: Schritt 4, Bild 1 von 2 HP Envy m6-1105dx RAM Replacement: Schritt 4, Bild 2 von 2
    • Push the silver levers on either side of the memory module away from the module.
    • Remove the memory module by gently pulling it on an angle away from the slot.
Abschluss
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G5, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G5
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 397
