Zum Hauptinhalt wechseln
HP Envy m6-1105dx WLAN Card Replacement
Was du brauchst
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: Schritt 2, Bild 1 von 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: Schritt 3, Bild 1 von 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: Schritt 4, Bild 1 von 2 HP Envy m6-1105dx WLAN Card Replacement: Schritt 4, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: Schritt 5, Bild 1 von 3 HP Envy m6-1105dx WLAN Card Replacement: Schritt 5, Bild 2 von 3 HP Envy m6-1105dx WLAN Card Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: Schritt 6, Bild 1 von 2 HP Envy m6-1105dx WLAN Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
Abschluss
Ian Mwalago
303 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G5, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G5
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 609
