Was du brauchst
Schritt 1 Battery
Achtung: Die Schritte 1-6 stammen von einer Anleitung, die derzeit bearbeitet wird.
Shut down the computer
Remove all external devices
Unplug the AC adapter
Schritt 7 Fan
Achtung: Die Schritte 7-9 stammen von einer Anleitung, die derzeit bearbeitet wird.
Remove the fan cable
Schritt 10 Touchpad
Achtung: Die Schritte 10-14 stammen von einer Anleitung, die derzeit bearbeitet wird.
Unscrew the 3 screws that hold the card reader board to the system
Raise the card reader board from the system
Remove the four screws that pin down the hard drive
Disconnect the harddrive from its connector
Remove the harddrive
Only complete this step if your computer model has a solid state drive
Remove the two screws at the top of the solid state drive
Remove the solid state drive
Remove the thirteen screws around the keyboard bracket
Gently remove the keyboard bracket from its top
Remove the 4 screws on the touchpad's board
Gently lift the touchpad board from the side that the screws were on
Remove the touchpad board
Lift the keyboard section of the computer up
Slide out the display
Remove the plastic bezel cover
Remove the ten screws holding the hinge to the display
Remove the four screws arouund the display
Remove the adhesive strip out of the true display
Disconnect the display's cable
Remove the display
