Zum Hauptinhalt wechseln
HP Envy m6-k022dx CMOS Battery Replacement
Was du brauchst
  1. HP Envy m6-k022dx CMOS Battery Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CMOS Battery Replacement: Schritt 2, Bild 1 von 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CMOS Battery Replacement: Schritt 3, Bild 1 von 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CMOS Battery Replacement: Schritt 4, Bild 1 von 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CMOS Battery Replacement, CMOS Battery: Schritt 5, Bild 1 von 1
    • There is a power cord connecting the CMOS battery to the motherboard. Disconnect this cord by gently pulling it up, towards the edge of the device.
  6. HP Envy m6-k022dx CMOS Battery Replacement: Schritt 6, Bild 1 von 1
    • Once the connecting cord has been disconnected, gently lift the battery directly up, above the device.
    • The CMOS battery is now completely removed, and ready to be replaced.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kareem Rigaud
403 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S13-G6, Cagle Spring 2017 Mitglied von USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 2,815
