Zum Hauptinhalt wechseln
HP Envy m6-k022dx RAM Replacement
Was du brauchst
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: Schritt 3, Bild 1 von 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: Schritt 4, Bild 1 von 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: Schritt 6, Bild 1 von 1
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: Schritt 7, Bild 1 von 1
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S13-G6, Cagle Spring 2017 Mitglied von USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 43
Insgesamt: 1,469
