Einleitung
This guide demonstrates how to properly remove the CPU of a HP Envy m6-n010dx.
Was du brauchst
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the small panel on the back by prying it off. This should reveal the hard drive.
Gently pry off the cover to release the cable.
Slowly lift the hard drive out and away from the device.
Remove the 6 highlighted 1.5 mm screws using a #00 philips head screwdriver.
Pry off the lower two grip pads highlighted in orange.
Remove the two additional 1.5mm screws underneath the lower grip pads using a #00 philips head screwdriver.
Remove the large back panel to reveal the inner workings.
The CPU can be found underneath the heatsink, highlighted in yellow.
Loosen the four 1.5 mm screws on the heat sink using a #00 philips head screwdriver.
Remove the tape holding the heatsink to the fan.
Remove the heatsink.
Find the uncovered CPU highlighted in red.
Turn the fastener, highlighted in orange, 180 degrees counterclockwise using a flat headed screwdriver to loosen the CPU.
To reassemble your device, follow these instructions in reverse order. Be sure to apply new thermal paste if you are using a new CPU.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
