Einleitung
This guide demonstrates how to properly remove the Hard Drive of a HP Envy m6-n010dx.
Was du brauchst
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the small panel on the back by prying it off. This should reveal the hard drive.
Gently pry off the cover to release the cable.
Slowly lift the hard drive out and away from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
