Zum Hauptinhalt wechseln
HP Envy m6-n010dx RAM Replacement
Was du brauchst
  1. HP Envy m6-n010dx RAM Replacement, Battery: Schritt 1, Bild 1 von 3 HP Envy m6-n010dx RAM Replacement, Battery: Schritt 1, Bild 2 von 3 HP Envy m6-n010dx RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx RAM Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx RAM Replacement: Schritt 3, Bild 1 von 2 HP Envy m6-n010dx RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx RAM Replacement: Schritt 4, Bild 1 von 3 HP Envy m6-n010dx RAM Replacement: Schritt 4, Bild 2 von 3 HP Envy m6-n010dx RAM Replacement: Schritt 4, Bild 3 von 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx RAM Replacement, RAM: Schritt 5, Bild 1 von 3 HP Envy m6-n010dx RAM Replacement, RAM: Schritt 5, Bild 2 von 3 HP Envy m6-n010dx RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Remove the highlighted screws
    • Pry off the lower two grip pads
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx RAM Replacement: Schritt 6, Bild 1 von 3 HP Envy m6-n010dx RAM Replacement: Schritt 6, Bild 2 von 3 HP Envy m6-n010dx RAM Replacement: Schritt 6, Bild 3 von 3
    • Pull back the black rectangular cover to reveal the RAM
    • Unclip the metal restraints on the side to pop out the RAM
    • Repeat the previous step for the second RAM below
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 301
