Einleitung
This guide demonstrates how to properly remove the Speaker of a HP Envy m6-n010dx.
Was du brauchst
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the small panel on the back by prying it off. This should reveal the hard drive.
Gently pry off the cover to release the cable.
Slowly lift the hard drive out and away from the device.
Remove the marked screws.
Pry off the lower two grip pads.
Remove the two additional screws underneath the lower grip pads.
Remove the large back panel to reveal the inner workings.
Locate the speaker.
Locate the tape on the speaker.
Peel back the tape, disconnecting it from the speaker.
