Zum Hauptinhalt wechseln
HP Envy x2 13-j002dx Screen Replacement
Was du brauchst
  1. HP Envy x2 13-j002dx Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Screen Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Screen Replacement: Schritt 4, Bild 1 von 2 HP Envy x2 13-j002dx Screen Replacement: Schritt 4, Bild 2 von 2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Screen Replacement: Schritt 5, Bild 1 von 1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Screen Replacement: Schritt 6, Bild 1 von 1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Screen Replacement: Schritt 7, Bild 1 von 2 HP Envy x2 13-j002dx Screen Replacement: Schritt 7, Bild 2 von 2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Screen Replacement: Schritt 8, Bild 1 von 1
    • Carefully lift up and remove the battery.
  9. HP Envy x2 13-j002dx Screen Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
  10. HP Envy x2 13-j002dx Screen Replacement: Schritt 10, Bild 1 von 2 HP Envy x2 13-j002dx Screen Replacement: Schritt 10, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
  11. HP Envy x2 13-j002dx Screen Replacement: Schritt 11, Bild 1 von 2 HP Envy x2 13-j002dx Screen Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
  12. HP Envy x2 13-j002dx Screen Replacement: Schritt 12, Bild 1 von 2 HP Envy x2 13-j002dx Screen Replacement: Schritt 12, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
    • Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
  13. HP Envy x2 13-j002dx Screen Replacement: Schritt 13, Bild 1 von 1
    • Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
  14. HP Envy x2 13-j002dx Screen Replacement, Screen: Schritt 14, Bild 1 von 1
    • Once the battery and motherboard are removed, the screen unit should offer little resistance. Remove the screen from the base.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Colton Moon
241 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 26
Insgesamt: 591
