Zum Hauptinhalt wechseln
HP Envy x360 15-bp143cl Touchpad Replacement
Was du brauchst
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 5, Bild 1 von 2 HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: Schritt 7, Bild 1 von 2 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: Schritt 7, Bild 2 von 2
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 8, Bild 1 von 2 HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 8, Bild 2 von 2
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 9, Bild 1 von 1
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 10, Bild 1 von 2 HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 10, Bild 2 von 2
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 11, Bild 1 von 2 HP Envy x360 15-bp143cl Touchpad Replacement: Schritt 11, Bild 2 von 2
    • Lift the touch pad to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S12-G3, Regan Fall 2019 Mitglied von Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Thanks now have to find one on E-bay….or?
Michael - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 1,471
