Zum Hauptinhalt wechseln
HP Envy x360 15-u473cl Battery Replacement
Was du brauchst
  1. HP Envy x360 15-u473cl Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Envy x360 15-u473cl Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Battery Replacement: Schritt 3, Bild 1 von 2 HP Envy x360 15-u473cl Battery Replacement: Schritt 3, Bild 2 von 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Battery Replacement: Schritt 4, Bild 1 von 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Battery Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 34
Insgesamt: 2,052
