Einleitung
The hard drive can wear out over time. This guide will show how to remove the hard drive inside the device.
Was du brauchst
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
Turn the device right side up and open the lid.
Insert the plastic opening tool in between the keyboard plate and the base of laptop.
Run the tool along seem, prying up as you go.
Separate the keyboard plate from the base, lifting from the front.
There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
Remove the keyboard plate from the device.
Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
Disconnect the battery from the motherboard.
There may be tamper-proof tape holding the battery in place. Remove the tape if present.
Remove the battery from the device.
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Remove the back cover by using the black spudger to lift up on the edges of the cover.
Using a suction cup to assist in lifting the back cover.
Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
Lift and pull the front of the battery up and out (away from the connector) to remover.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
