Zum Hauptinhalt wechseln
HP Envy x360 15m-bp111dx Battery Replacement
Was du brauchst
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp111dx Battery Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp111dx Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: Schritt 3, Bild 1 von 2 HP Envy x360 15m-bp111dx Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 15m-bp111dx Battery Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 15m-bp111dx Battery Replacement: Schritt 4, Bild 3 von 3
    • Carefully lift the battery, and pull it towards you to remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tori Luongo
268 Reputation
2 Anleitungen geschrieben
Clemson, Team 2-2, Hunter Spring 2022 Mitglied von Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
This website has been very helpful but you only show how to remove a battery. You've left out the replace part of the replacement. Would really help. Thanks!
book mite - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 829
