Einleitung
This guide will assist in locating, removing, and replacing the charging port for your HP Envy x360 15m-bp111dx. You may need to replace this component if your laptop is not charging properly. Be sure to troubleshoot your HP Envy x360 15m-bp111dx to ensure that this is not an issue concerning the battery. You can verify this with our troubleshooting guide here.
Be sure that your laptop is powered off, disconnected from the charging adapter, and that the components have cooled before beginning this replacement.
Was du brauchst
Remove the rubber feet to access the screws.
Using a Phillips #0 screwdriver, remove the four 7 mm screws.
Using a T5 Torx screwdriver, remove the three 5 mm screws.
Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
Remove the back case.
Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
Lift and move the speaker to the side.
Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
Use the opening tool to raise the hinge.
Then lift the hinge by hand to provide enough clearance to remove the charging port.
Gently slide the charging port connector out of the port, and lift it above the hinge.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
