Zum Hauptinhalt wechseln
HP Envy x360 15m-bp111dx Charging Port Replacement
Was du brauchst
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: Schritt 3, Bild 1 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: Schritt 3, Bild 2 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 4, Bild 1 von 2 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 6, Bild 1 von 2 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 7, Bild 1 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 7, Bild 2 von 3 HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 7, Bild 3 von 3
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Remove the charging port.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tori Luongo
268 Reputation
2 Anleitungen geschrieben
Clemson, Team 2-2, Hunter Spring 2022 Mitglied von Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 703
