Zum Hauptinhalt wechseln
HP Envy x360 15m-bp111dx Hard Drive Replacement
Was du brauchst
  1. HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: Schritt 3, Bild 1 von 2 HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • The hard drive bay is located in the lower left corner of the computer.
    • The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
  6. HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Pull the rubber casing away from the drive (not pictured here) and gently lift the hard drive out of the computer.
    • Unplug the drive from power by grabbing the SATA / power cable on the plastic edge and pulling it away from the drive.
    • Do not disconnect the ribbon cable from the motherboard.
  7. HP Envy x360 15m-bp111dx Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • The hard drive is now removed and can be replaced.
Abschluss
Ross Snead
162 Reputation
1 Anleitung geschrieben
Clemson, Team 2-2, Hunter Spring 2022 Mitglied von Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 24
Insgesamt: 522
