Zum Hauptinhalt wechseln
HP Envy x360 15m-bp111dx Touchpad Replacement
Was du brauchst
  1. HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bp111dx Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: Schritt 3, Bild 1 von 2 HP Envy x360 15m-bp111dx Touchpad Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: Schritt 5, Bild 2 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement, Touchpad: Schritt 5, Bild 3 von 3
    • Use a Phillips screwdriver to remove the four 3.5 mm screws securing the bar on the touchpad.
    • Remove the bar from the touchpad.
  6. HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 6, Bild 1 von 2 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips screwdriver to remove the three 2 mm screws securing the touchpad.
  7. HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 7, Bild 1 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 7, Bild 2 von 3 HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Flip the lock open on the ZIF connector using the opening tool to detach the ribbon from the motherboard.
    • Gently remove the touchpad from the motherboard.
  8. HP Envy x360 15m-bp111dx Touchpad Replacement: Schritt 8, Bild 1 von 1
    • The touchpad is now removed.
Abschluss
Clemson, Team 2-2, Hunter Spring 2022 Mitglied von Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 19
Insgesamt: 297
