Zum Hauptinhalt wechseln
HP Envy x360 15m-bp112dx Hard Drive Replacement
Was du brauchst
  1. HP Envy x360 15m-bp112dx Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP Envy x360 15m-bp112dx Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
Abschluss
Mohamed Kozamel
121 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Mitglied von UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 14
Insgesamt: 241
