Einleitung
Use this guide to replace the hard drive for the HP Envy x360 15m-bp112dx. Hard drives are used to store data in the long term on a computer, such as files, photos, and videos. Some reasons to replace the hard drive include upgrading it or the laptop fails to boot up when powering it on.
Was du brauchst
Start by facing the device upside down with the hinge facing away from you.
Remove the seven 1 mm Phillips screws.
Use an opening tool to pry the back panel by pushing the bottom cover upwards.
Place the bottom cover away from the laptop.
Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
Remove the hard drive by pulling it out vertically.
Remove the plastic casing around the hard drive by peeling it back.
Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
