Zum Hauptinhalt wechseln
HP Envy x360 15m-bq021dx Display Replacement
Was du brauchst
  1. HP Envy x360 15m-bq021dx Display Replacement, Battery: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bq021dx Display Replacement, Battery: Schritt 1, Bild 2 von 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Display Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bq021dx Display Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bq021dx Display Replacement: Schritt 2, Bild 3 von 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Display Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Display Replacement: Schritt 4, Bild 1 von 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Display Replacement: Schritt 5, Bild 1 von 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Display Replacement, Cooling Fan: Schritt 6, Bild 1 von 2 HP Envy x360 15m-bq021dx Display Replacement, Cooling Fan: Schritt 6, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Display Replacement: Schritt 7, Bild 1 von 2 HP Envy x360 15m-bq021dx Display Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Display Replacement: Schritt 8, Bild 1 von 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Display Replacement: Schritt 9, Bild 1 von 2 HP Envy x360 15m-bq021dx Display Replacement: Schritt 9, Bild 2 von 2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Display Replacement, Motherboard: Schritt 10, Bild 1 von 3 HP Envy x360 15m-bq021dx Display Replacement, Motherboard: Schritt 10, Bild 2 von 3 HP Envy x360 15m-bq021dx Display Replacement, Motherboard: Schritt 10, Bild 3 von 3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Display Replacement: Schritt 11, Bild 1 von 3 HP Envy x360 15m-bq021dx Display Replacement: Schritt 11, Bild 2 von 3 HP Envy x360 15m-bq021dx Display Replacement: Schritt 11, Bild 3 von 3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Display Replacement: Schritt 12, Bild 1 von 2 HP Envy x360 15m-bq021dx Display Replacement: Schritt 12, Bild 2 von 2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Display Replacement, Speakers: Schritt 13, Bild 1 von 1
    • Use the tweezers to remove the cords from their restraints.
    • Lift the speakers out of the laptop.
  14. HP Envy x360 15m-bq021dx Display Replacement, Display: Schritt 14, Bild 1 von 1
    • Remove the three 4.4 mm screws from each hinge using a Phillips #0 screwdriver.
  15. HP Envy x360 15m-bq021dx Display Replacement: Schritt 15, Bild 1 von 1
    • Lift the hinges with the spudger.
  16. HP Envy x360 15m-bq021dx Display Replacement: Schritt 16, Bild 1 von 1
    • Use the spudger to detach the the screen from the display.
  17. HP Envy x360 15m-bq021dx Display Replacement: Schritt 17, Bild 1 von 1
    • Slowly remove the tape.
  18. HP Envy x360 15m-bq021dx Display Replacement: Schritt 18, Bild 1 von 1
    • Disconnect the wire from the ports and take out the white sheet.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 897
