Zum Hauptinhalt wechseln
HP Envy x360 15m-bq021dx Hard Drive Replacement
Was du brauchst
  1. HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use the tweezers to lift up the retaining flap on the cable connector.
    • Pull out the ribbon cable from the connector.
  7. HP Envy x360 15m-bq021dx Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Use the spudger to lift the hard drive from the cutout.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Followed guide to remove HDD from 15m-bq121dx model. Steps were identical. Took more force than I expected to remove bottom cover and to get the HDD out.
Adam Francis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 772
