Zum Hauptinhalt wechseln
HP Envy x360 15m-bq021dx RAM Replacement
Was du brauchst
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bq021dx RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bq021dx RAM Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bq021dx RAM Replacement: Schritt 2, Bild 3 von 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 4, Bild 1 von 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 5, Bild 1 von 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: Schritt 6, Bild 1 von 1
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 7, Bild 1 von 2 HP Envy x360 15m-bq021dx RAM Replacement: Schritt 7, Bild 2 von 2
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 8, Bild 1 von 1
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: Schritt 9, Bild 1 von 2 HP Envy x360 15m-bq021dx RAM Replacement: Schritt 9, Bild 2 von 2
    • Pull the RAM up and out to remove.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 1,692
