Zum Hauptinhalt wechseln
HP Envy x360 15m-bq121dx Cooling Fan Replacement
Was du brauchst
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: Schritt 1, Bild 2 von 2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 5, Bild 1 von 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 6, Bild 1 von 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 8, Bild 1 von 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove the cooling fan.
Abschluss
Fabien Perez
157 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 2,310
