Einleitung
This guide will demonstrate how to replace the RAM in the HP Envy x360 15m-cn0011dx laptop. When replacing or reinserting the RAM, make sure to place it properly with the notch on the bottom of the RAM.
Make sure your device is fully powered off before attempting this guide.
Was du brauchst
Remove the six 5.6 mm screws from the back cover using a Phillips #00 screwdriver.
Remove the single 4.3 mm screw in the bottom middle section of the back cover using a T5 Torx screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
