Zum Hauptinhalt wechseln
HP Envy x360 15m-cn0012dx Daughterboard Replacement
Was du brauchst
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: Schritt 1, Bild 1 von 2 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: Schritt 1, Bild 2 von 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 3, Bild 1 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 3, Bild 2 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 3, Bild 3 von 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 4, Bild 3 von 3
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 5, Bild 1 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 5, Bild 2 von 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Grace Daleki
499 Reputation
3 Anleitungen geschrieben
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 963
