Zum Hauptinhalt wechseln
HP Envy x360 15m-cn0012dx Hard Drive Replacement
Was du brauchst
  1. HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Envy x360 15m-cn0012dx Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove one screw from the bottom left corner of the laptop.
    • Use the iFixit opening tool to lift the latch and detach the connector to the motherboard.
    • Remove the hard drive.
    • When replacing the hard drive, you will likely have to transfer the SATA cable and hardware from your old drive to the new one before reinstalling.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Grace Daleki
487 Reputation
3 Anleitungen geschrieben
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 70
Insgesamt: 6,904
