Zum Hauptinhalt wechseln
HP Envy x360 m6-aq005dx Battery Replacement
Was du brauchst
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 m6-aq005dx Battery Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 m6-aq005dx Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: Schritt 4, Bild 1 von 2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S13-G17, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - Antwort
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - Antwort
Excellent guide, many thanks for posting it.
stephenm.race - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 16,000
