Zum Hauptinhalt wechseln
HP Envy x360 m6-aq005dx Touchpad Replacement
Was du brauchst
  1. HP Envy x360 m6-aq005dx Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 m6-aq005dx Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Touchpad Replacement, Battery: Schritt 4, Bild 1 von 2 HP Envy x360 m6-aq005dx Touchpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  6. HP Envy x360 m6-aq005dx Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 1
    • Carefully, pull back the locking clip of the connector using a plastic opening tool and disconnect cable.
  7. HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 7, Bild 1 von 2 HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 7, Bild 2 von 2
    • The red square contains two screws side by side.
    • Using a PH0 bit remove the 7 (2.8 mm) screws securing the touchpad to the device.
  8. HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 8, Bild 1 von 2 HP Envy x360 m6-aq005dx Touchpad Replacement: Schritt 8, Bild 2 von 2
    • Keep the ribbon cable from interfering with touchpad removal.
    • Use a plastic opening tool to pry up the touchpad.
    • Gently, pull out the touchpad from device.
Abschluss
Darrin Smiley
261 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S13-G17, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 1,122
