Einleitung
Is your HP Envy x360 m6-aq103dx not holding a charge like it used to? If so, here is the guide to fix this problem by simply changing the battery. All you need is a #1 Phillips Screwdriver, a T5 Torx screwdriver heads, the nylon black spudger, and the plastic opening tool in order to remove the five types of screws involved with this replacement.
Was du brauchst
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
Lift up the port with the tool.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
