Zum Hauptinhalt wechseln
HP Envy x360 m6-aq103dx Bottom Cover Replacement
Was du brauchst
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: Schritt 3, Bild 1 von 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: Schritt 4, Bild 3 von 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Sarah Samora
777 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S4-G3, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Mitglieder
9 Anleitungen geschrieben
4 Kommentare
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - Antwort
It was really easy to open.
[deleted] - Antwort
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - Antwort
But where can i purchase the bottom cover
imran abdulhameed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 8,757
