Einleitung
Is the CPU fan in your HP Envy x360 m6-aq103dx not functioning correctly? Follow this easy replacement guide to open up your computer and replace the CPU fan.
Was du brauchst
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
Remove the cable from the connector.
Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
Using your fingers, peel the tape off of the body of the computer.
Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
4 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Step 5-7 can be bypassed I didn’t need to do it
My first home repair so far. Really easy to follow guide. Great job!
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
