Zum Hauptinhalt wechseln
HP Envy x360 m6-aq105dx Back Cover Replacement
Was du brauchst
  1. HP Envy x360 m6-aq105dx Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 544
