Einleitung
This guide will show how to remove the back cover to your HP Envy. In most cases, this is the first step to fixing most components within the laptop.
Was du brauchst
Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
Remove the six 5.2 mm screws using the Torx T5 screwdriver.
Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Fast fertig!
Abschluss
