Zum Hauptinhalt wechseln
HP Envy x360 m6-w101dx Fan Replacement
Was du brauchst
  1. HP Envy x360 m6-w101dx Fan Replacement, Keyboard Panel: Schritt 1, Bild 1 von 1
    • Place the laptop so that the bottom panel is facing upwards.
  2. HP Envy x360 m6-w101dx Fan Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 m6-w101dx Fan Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 m6-w101dx Fan Replacement: Schritt 2, Bild 3 von 3
    • Remove the screw covers using an iFixit opening tool.
  3. HP Envy x360 m6-w101dx Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove twelve 8 mm Phillips #1 screws.
  4. HP Envy x360 m6-w101dx Fan Replacement: Schritt 4, Bild 1 von 3 HP Envy x360 m6-w101dx Fan Replacement: Schritt 4, Bild 2 von 3 HP Envy x360 m6-w101dx Fan Replacement: Schritt 4, Bild 3 von 3
    • Pry open a gap in the edge of the keyboard with an iFixit opening tool.
  5. HP Envy x360 m6-w101dx Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the keyboard from the laptop.
  6. HP Envy x360 m6-w101dx Fan Replacement, Fan: Schritt 6, Bild 1 von 1
    • Remove the five 4.5mm Phillips #1 screws surrounding the fan.
  7. HP Envy x360 m6-w101dx Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 4.5mm Phillips #1 screws from right side of the motherboard.
  8. HP Envy x360 m6-w101dx Fan Replacement: Schritt 8, Bild 1 von 1
    • Detach the cable between the CPU and the motherboard.
  9. HP Envy x360 m6-w101dx Fan Replacement: Schritt 9, Bild 1 von 1
    • Detach the cable between the battery and the motherboard.
  10. HP Envy x360 m6-w101dx Fan Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the cable between the SD card and the motherboard.
  11. HP Envy x360 m6-w101dx Fan Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the cable between the screen and the motherboard.
  12. HP Envy x360 m6-w101dx Fan Replacement: Schritt 12, Bild 1 von 1
    • Detach the connection between the fan and the motherboard.
  13. HP Envy x360 m6-w101dx Fan Replacement: Schritt 13, Bild 1 von 1
    • Disconnect the cable from the speaker to the motherboard.
  14. HP Envy x360 m6-w101dx Fan Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the cable between the CPU and the power interface.
  15. HP Envy x360 m6-w101dx Fan Replacement: Schritt 15, Bild 1 von 1
    • Turn the connected motherboard and fan upside down and remove the four 4.5mm Phillips #1 screws from the middle of the back of the motherboard.
  16. HP Envy x360 m6-w101dx Fan Replacement: Schritt 16, Bild 1 von 1
    • Disconnect the cable connecting the fan to the motherboard.
  17. HP Envy x360 m6-w101dx Fan Replacement: Schritt 17, Bild 1 von 1
    • Remove the fan from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S8-G5, Turner Winter 2020 Mitglied von York University, Team S8-G5, Turner Winter 2020
YORK-TURNER-W20S8G5
5 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 647
